Hi
Conventional CH system, waster cylinder and CH header tank in the loft. Boiler is a Potterton Suprima. Should the boiler remain on until the temperature set by thermostat is obtained? Even if I set thermostat to 30 deg the boiler cuts out (not locking out), just stops then re-starts some time later.
Is this normal practice? If the boiler was over heating, would the light on the boiler turn red or flash?
