    Dismiss Notice
Boiler flue missing screws?
Discussion in 'Plumbing and Central Heating' started by vegasgo, 17 Oct 2019.
  1. vegasgo
    vegasgo
    6 Jul 2004
    111
    Thanks Received:
    Country:
    Hello. We had our boiler fixed today and the engineer said we're missing vital screws from the flue. See pic below. It's been like this for ten years and always passed its service, was in place before we moved in. Any advice appreciated, thanks.
    [​IMG]
  2. Sponsored Links
  3. Iamchamps
    Iamchamps
    24 Sep 2016
    1,035
    Thanks Received:
    162
    Country:
    If he was that concerned and as he is the last gas safe person there he should have condemned it if he thought it was a problem. I am assuming he hasn’t so I wouldn’t worry.
  4. vegasgo
    vegasgo
    6 Jul 2004
    111
    Thanks Received:
    Country:
    I had to sign a disclaimer before he fixed the boiler.
  5. Iamchamps
    Iamchamps
    24 Sep 2016
    1,035
    Thanks Received:
    162
    Country:
    Doesn’t matter what you signed as a gas safe engineer he can’t walk out of there with a gas item at risk. So if he didn’t shut it down it can’t be a big problem.
  6. Chris_W
    Chris_W
    26 Sep 2019
    6,043
    Thanks Received:
    1,588
    North
    Country:
    Check with the manufacturer, it could be an advisory from him/her
  7. Alec_t
    Alec_t
    18 Mar 2017
    649
    Thanks Received:
    119
    Wales
    Country:
    Just bung some screws in there so that he doesn't complain on the next visit :).
  8. Chris_W
    Chris_W
    26 Sep 2019
    6,043
    Thanks Received:
    1,588
    North
    Country:
    The screws in the turret are manufacturer supplied generally, so can’t see why they pull you for that?
  9. vegasgo
    vegasgo
    6 Jul 2004
    111
    Thanks Received:
    Country:
    I could put extra screws in but told would pierce inner casing if too deep
  10. Sponsored Links
  11. gasbusters
    gasbusters
    27 Sep 2016
    4,904
    Thanks Received:
    485
    Country:
    They are usually about 25mm max
  12. mattylad
    mattylad
    27 Apr 2008
    7,826
    Thanks Received:
    567
    Country:
    use short screws.
    Or cut down screws.
  13. johnny2007
    johnny2007
    11 Jan 2012
    3,011
    Thanks Received:
    466
    London
    Country:
    That screw only prevents anyone from sliding off the flue when cleaning or decorating.
    Some technicians like to scare customers.
    If you really have to, you will see a notched point in the outer skin.
    Drill a hole through the 2 metal part of the flue with a 3mm hss bit.
    Then screw a 15mm self tapping in there.
    Job done.
    An insurance technician once tried to charge me £80 for this.
    I told him to get out of the way and did it myself in 2 minutes with him there.
    He didn't even fix the fault he was called for, all he wanted was to charge me for extra work and sign me up for boiler cover which i already had on my house insurance.
    Scumbag!
    • Like Like x 1
  14. ianmcd
    ianmcd
    15 Aug 2010
    20,891
    Thanks Received:
    8,116
    Lanarkshire
    Country:
    No do not try to do any work on your own flue
    • Like Like x 1
  15. vegasgo
    vegasgo
    6 Jul 2004
    111
    Thanks Received:
    Country:
    I wouldn't touch it myself, don't worry. It feels sturdy and has been like this for 10 years, no leaks ever detected, just wondered how important these missing screws are.
  16. johnny2007
    johnny2007
    11 Jan 2012
    3,011
    Thanks Received:
    466
    London
    Country:
    Not important at all in my case.
    It was such a tight fit and cemented through the wall with styrofoam in the cavity that nothing could've "accidentally " moved it.
  17. martyndc88
    martyndc88
    26 Apr 2009
    933
    Thanks Received:
    197
    South Glamorgan
    Country:
    There are two screws missing. But as above do not screw yourself.
    • Like Like x 1
Loading...
Share This Page
