I want to have my boiler moved from the kitchen (downstairs) to the bathroom upstairs for various practicality reasons.
The system is pumped indirect hot water and microbore heating with motorised valve, room stat and cylinder stat. Cylinder is sited upstairs next to bathroom where i want the new boiler and the system is not a sealed system. Automatic bypass and TRVs are to be fitted to system at same time as new boiler.
I have bought the new boiler. It is a standard gas condensing unit (i.e. not a system boiler) and will use all of the pipework etc of the old unit pretty much without too much changing.
I am being told that there may be a problem with siting the boiler upstairs because it will mean that there is no longer a continuous fall on the vent (expansion) pipe to the header tank.
It is true that this is the case and the circuit would go down under the floor and then back up the wall breaking the continuity of the fall, but i have seen hundreds of boiler plumbed from the floor up and not the ceiling down.
I really want to have the unit moved to the bathroom. Can anybody tell me if there is truth to this problem, and if so is it a minor consideration/efficiency consideration, or is it an absolute must.
Thanks for your help,
Don
Don
