Hi i have a glow worm compact e100, i recently checked, bled my radiators no air was found everything seems ok. However when i turn the thermostat on to turn central heating on "boiler lockout" light comes on. i press the reset button and boiler ignites and seems to run fine. I never had the problem prior to bleeding radiators so i am assuming the two things are linked? any ideas? (I repressurized the system to just over 1 bar.)
Also an ongoing problem is receiving hot water i have had the diaphram replaced but have been told to replace the domestic hot water micro switch, could someone tell me which microswitch is the hot water one is it the 2 core one or the 3 core one i phoned a boiler parts supplier but he did not know i assume its the one on the left when looking at it?
