Boiler nightmare
13 Mar 2015
Kent
I've been trying to locate parts for my Glowworm Fuelsaver F boiler, need an extension on the flue outlet for conservatory regulations.
Everyone contacted tells me to scrap boiler and upgrade, boilers working fine I'm not in the habit of dumping it on basis of one part since it's in good working order.
Does anyone know if parts can be located or if a custom made pipe would be a viable option?
Thanks,
Alex84
Doubt you'll get any parts for the flue, and even so I don't recall being able to extend that flue. A custom made flue is a very bad idea.
There was an internal extension kit, but I think you'll find it hard if not impossible to find one.
Not a cat in hell's chance of getting a flue extension for that I'm afraid. Can the boiler be moved? If not then it's new boiler time
Your boiler might be working fine now, but it won't once the Conservatory is built!! good advice already given new boiler - shouldn't cost that much to do not as much as your new conservatory! and you should have costed the boiler issue into the cost of the Build! :shock:
