D
Deleted member 267285
Wrong thread
My system makes a racket when air gets into the heating circuit, have you tried bleeding and checked for minor leaks ?
Either circuit .Thanks, but this is currently on my hot water side?
Either circuit .
No bleed at boiler .Sorry, I’m not following. If I bleed my radiators, for hot water, this may cure the boiler clunk noise?
Feel the HW zone valve when it is making the noise, I have seen them with a tooth sheared on the gear mechanism, and it makes a clunking noise
Not really dangerous, actually sounds a lot worse than it really is, not something I would leave long term though as if too low it can cause cracks in the burnerThank you very much, at least I know what it is. Is it dangerous, or can it be left until I can get someone in?
