- Joined
- 26 Aug 2020
- Messages
- 28
- Reaction score
- 2
- Country
I have a bit of a quandry I'm hoping someone may be able to shed some light on. In a nutshell, THE BOILER WONT FIRE UP!
I have the following system:
Ideal Classic FF240 Boiler (probably 20 years old)
Nest 3rd Generation Thermostat
Hot Water Tank
Tank in attic
Worth noting: This boiler doesnt have an "always on" pilot light. When the Nest tells it to come on for CH/HW, the gas is pumped and the boiler sparks to ignite
When the stat sends the message to the boiler, I can hear a click from under the stairs (where the distributor valve, pump and hot water tank is) and a faint click inside the boiler cupboard from the boiler, as well a faint whirring sound and then nothing. Its like everything is working up until the boiler and then the final message to spark to ignite is not happening despite the rest of the system working up to that point. I know this click in the boiler isnt the ignition spark as that is louder and actually clicks twice on ignition
This issue has been happening on and off for around a year now and we're now on the third go round of this particiular problem. Whats annoying is it eventually sorts itself out after a week or 2 and then works fine again for 3 - 6 months before failing again
Previously we've called a plumber and booked in and by the time the plumber is due to arrive, it is working again and have had to cancel however this ongoing problem isnt ideal and I'd like to try and work out whats going on with it
Because it does have long periods of actually working, its confusing as to what it could be because when it does work, it works perfectly
Any ideas???
Hot Water Tank
Tank in attic
Any ideas???
