Hi had a boiler fitted and it looks tilted, I thought it was possibly the window making it look out of true but the window casing is as near as damn it level (.1deg vertical) so I put my level on on the boiler casing and it’s 1.4 deg off vertical, so it might just be the casing that’s been fitted off kilter.
my question is, would this tilt; if the internal parts are fitted tilted make any difference to the boilers function or is it just an aesthetic thing that can be corrected by adjusting the case and regardless of whether the internal working are slightly out of true the boilers function will not be affected.
Are there tolerances for this sort of thing?
