    Dismiss Notice
Boiler not reaching thermostat temperature
Discussion in 'Plumbing and Central Heating' started by symbiosis, 11 Jan 2019.
  1. symbiosis
    symbiosis
    21 Jan 2017
    37
    Thanks Received:
    Country:
    Hi all
    I have a fairly ageing TURBOmax VUW 242 Vailent boiler.
    I Have my room thermostat set to 21 but just recently the boiler is cutting out at no more than 17. The rads are hot but the rooms are not!
    I have noticed that the pressure has creped up from a fairly steady 1.5 bar to just under 3 bar
    Any thoughts please?
  2. Sponsored Links
  3. KenGMac
    KenGMac
    24 Aug 2010
    2,856
    Thanks Received:
    496
    Ayrshire
    Country:
    symbiosis, good evening.
    OK no answer to your pressure fluctuations.
    Can I suggest that you check the validity of the readings that the room stat is giving you, the Stat is set to "XXX" but is the Stat accurate?
    Ken
  4. terryplumb
    terryplumb
    8 May 2017
    3,893
    Thanks Received:
    783
    Country:
    Probably an expansion vessel problem causing the rise to 3 bar. What does pressure drop to when boiler is off ,and cooled down ?
    Raise the target temp on stat to 25 degrees and see what you get !!
  5. fixitflav
    fixitflav
    20 Mar 2018
    697
    Thanks Received:
    59
    Stoke-on-Trent
    Country:
    I'd try turning the boiler control-stat up, see if that helps. There might be a high-pressure cut-out stopping it at 3 bar. The pressure problem needs sorting anyway, probably the vessel as terryplumb said.
    • Like Like x 1
  6. symbiosis
    symbiosis
    21 Jan 2017
    37
    Thanks Received:
    Country:
    thanks for the replies, pressure goes to 2 bar when off (again much higher than before), was also wondering expansion vessel
  7. McCombi
    McCombi
    9 Jun 2012
    2,508
    Thanks Received:
    614
    Aberdeenshire
    Country:
    Undersized rads for the rooms maybe?
    • Like Like x 1
  8. Sponsored Links
  9. Gasguru
    Gasguru
    9 Sep 2005
    11,013
    Thanks Received:
    2,777
    Sussex
    Country:
    Filling loop valves on the T'max Plus are rubbish...there's every chance they are chewed up and allowing the system pressure to rise to mains pressure.
    The vessel will likely be low on charge or failed...needs looking at.
    Have you got the boiler heating thermostat turned up sufficient?
    If the radiator is kicking out heat at say 75 degrees (average across its surface) and the room is not reaching your target temperature it is too small for the rooms heat loss.
    • Like Like x 1
  10. John D v2.0
    John D v2.0
    26 Aug 2016
    6,315
    Thanks Received:
    876
    Country:
    If the radiators are boiling and the room is not warm enough then there's unlikely to be an issue with the boiler even if it is cutting in and out, it's just doing that to stop the system water overheating until the heat is lost from the radiators
    • Like Like x 1
  11. symbiosis
    symbiosis
    21 Jan 2017
    37
    Thanks Received:
    Country:
    Thanks for the replies, some more info:
    Boiler is shutting off at about 50 on its temp gauge
    Not had this issue previously and house has always been a toasty 21 even in the coldest of weather (its a bungalow so only 6 rads) so i thik can rule out undersized rads
    Would the pressure remain high (2 bar) when off if the pressure vessel needs priming or does that point to something else?
  12. Gasguru
    Gasguru
    9 Sep 2005
    11,013
    Thanks Received:
    2,777
    Sussex
    Country:
    You should set the pressure to around 1 bar with the rads cold and the pressure should ideally not rise to more then 2 bar when red hot.
    Does the heating temp control on the boiler respond?
  13. McCombi
    McCombi
    9 Jun 2012
    2,508
    Thanks Received:
    614
    Aberdeenshire
    Country:
    If it’s shutting off at 50 then turn stat higher on boiler
    • Like Like x 1
  14. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
