boiler pressure dropped
18 Mar 2007
Hi i have a worcester greenstar 40 CDI combi. The pressure has dropped significantly as I removed and drained a radiator for decorating purposes. As a consequence the system needs topping up, but I am unsure how to do it. I believe my boiler has an internal filling loop, what should this look like and how do I remedy the situation. any advice greatfully received :)
Hi thanks I had a look and it doesn't tell you anywhere how you do this, just says if the pressure drops to get one of their engineers to come out!! However, wanted to do this myself
Do they still use the plastic filling link on this model? If so you will have a 'T' shaped plastic key that has to be inserted under the boiler and turned to fill up system. If all else fails put hose on drain point and back fill :wink:
thanks for all your advice. there is a plastic key which I have inserted and turned to fill the system. The radiators are all hot downstairs now but the upstairs radiators do not seem to be filling?? any ideas
You also have to turn on a separate tap under the boiler (very near to white filling key) to get the water to flow in.
Fill to about 1 bar, bleed upstairs rads, refill to 1 bar, then turn off tap and remove white key.
THANK YOU SOOO MUCH meldrew's mate job is now done and all is working perfectly.
Much thanks to you :D
