K
keego
BDL said:Not wishing to sound negative. But the only way water can enter the fan is via the heat exch. The fan is attached to the burner, the water leaks from the heat exchanger thru burner into fan.
If you get the burner removed you will see the water marks on the burner/probes.
It could be rain water from the flue, but this would cause water to leak thru the air intake as well and water would be evident on the outside wrap of the heat exch.
If you need a heat exch. I know a place that stocks them at reasonable cost.
Between 1 and 2 hrs to replace one.
Wrong, it can enter through the flue if there is a fall back into the boiler, last year I came down one morning to find water dripping out of the boiler, I thought the H/E had gone. But above the flue was an overflow from the toilet that had been running all night & was running over the flue & into the fan.
