    Dismiss Notice
Boiler question
Discussion in 'Plumbing and Central Heating' started by Android 07, 4 May 2021.
  1. Android 07
    Android 07
    24 Feb 2020
    452
    Thanks Received:
    23
    Essex
    Country:
    I have a 10 year old Worcester Bosch Greenstar boiler in a property I just bought.
    The boiler has a strange issue. The pressure drops down to zero leading to no hot water and then if you re-pressure using the key at the bottom, the boiler works for a couple of hours before the pressure goes down to zero again.
    I called out a gas engineer and on his first visit, he found that the pipe leading outside was leaking. He did something to fix it but this did not fix anything. He came back for a second visit and poured in three bottles of Fernox leak sealer. He advised me to run the heating for a couple of hours. This did not fix the issue either! In fact, the pressure now drops faster than before.
    The boiler also has this chugging noise all the time - not sure if this is the norm with this model.
    I called Worcester and they said that the heat exchanger has a warranty of 10 years.
    If an engineer turns up to fix it, it will cost me £128 and this part will be free.
    If the engineer finds any other issues, it will cost me £300 in total.
    I can also take a subscription where I pay £50 for 6 months and during this time, they will fix any issues with the boiler. If they cannot, they will give me £750 towards a new boiler.
    What do I do ?
  2. Sponsored Links
  3. sxturbo
    sxturbo
    12 Jan 2014
    3,629
    Thanks Received:
    532
    Essex
    Country:
    Make sure there's not a leak from the pipes.
    Then do the £50 per month option
    • Like Like x 1
  4. kidgreen61
    kidgreen61
    8 Mar 2009
    2,345
    Thanks Received:
    537
    Staffordshire
    Country:
    I would want to know which pipe outside is dripping.
    If its the copper pipe, then you need a simple repair.
    If it's a plastic pipe, then as turbo says.
  5. Harry Bloomfield
    Harry Bloomfield
    30 Dec 2018
    7,433
    Thanks Received:
    1,057
    Country:
    It could even be the PRV passing water, or more than just condensate coming out of the condensate drain - the OP needs to find out.
  6. ianmcd
    ianmcd
    15 Aug 2010
    22,700
    Thanks Received:
    9,118
    Lanarkshire
    Country:
    set the pressure at 1.0 bar when cold then run heating, if press guage goes up to near 3 you have an expansion problem and no amount of leak sealer will fix it
    • Like Like x 3
  7. CBW
    CBW
    26 Sep 2019
    8,365
    Thanks Received:
    2,187
    North
    Country:
    And may do more harm than good. Not sure if Worcester would use this as a get out clause either?
    • Like Like x 2
    • Thanks Thanks x 1
  8. Android 07
    Android 07
    24 Feb 2020
    452
    Thanks Received:
    23
    Essex
    Country:
    I can't see any more leaks, nothing around the radiators.
    It was the copper pipe and the engineer repaired it. On his second visit, he felt the pipe and there were no leaks anymore.
    I did, the pressure does not go up.
  9. Android 07
    Android 07
    24 Feb 2020
    452
    Thanks Received:
    23
    Essex
    Country:
    Is there any point in paying £300 on a 10 year old boiler? Would I be better off getting a new boiler?
  10. Sponsored Links
  11. Harry Bloomfield
    Harry Bloomfield
    30 Dec 2018
    7,433
    Thanks Received:
    1,057
    Country:
    As a customer, I would not put that much into a 10 year old boiler.
    • Like Like x 1
  12. Android 07
    Android 07
    24 Feb 2020
    452
    Thanks Received:
    23
    Essex
    Country:
    Shall we call a vote? Time for a new boiler? :cry:
  13. Mottie
    Mottie
    27 Feb 2017
    18,164
    Thanks Received:
    1,848
    Essexshire
    Country:
    The
    Neither would I. If times were hard though, a lot of people would have no choice and be able to pay out £1.5-£2k+ to have a new one fitted.
    • Like Like x 1
  14. ianmcd
    ianmcd
    15 Aug 2010
    22,700
    Thanks Received:
    9,118
    Lanarkshire
    Country:
    And what if it isnt the boiler ?
    • Like Like x 1
  15. Dangee
    Dangee
    5 Apr 2017
    4,090
    Thanks Received:
    404
    London
    Country:
    When you are going out all day, turn power off to boiler.VERY IMPORTANT.
    With boiler (heating) cold & pump not running, repressurise to exactly 1bar. (Take photo of p gauge) fully close flow & return isolation valves. Leave it. Check again when you come home, compare gauge with photo. If it’s dropped, it’s the boiler.
    • Like Like x 1
  16. Mottie
    Mottie
    27 Feb 2017
    18,164
    Thanks Received:
    1,848
    Essexshire
    Country:
    Then he can put the old one back and look elsewhere but as said, check and double check first.
  17. Harry Bloomfield
    Harry Bloomfield
    30 Dec 2018
    7,433
    Thanks Received:
    1,057
    Country:
    That was not the question asked.
Loading...
Share This Page
