Long time reader, first time poster..
I have been having some issues with my RCD circuit / boiler.
I have a Worcester 24i Junior Combi Boiler installed and when I have it set to 3 on the boiler there are no issues, but when I change it to anything above it trips the RCD.
I called an electrician to test the circuit for any earth leakages but his testing equipment showed everything is ok, he also tested the RCD and there were no issues.
I called the plumber who installed the boiler who could not find any issues.
I called Worcester who replaced the fan, the pump and various other components and it is still occurring. The final time the RCD tripped when the engineer was here, it would not come back on so he removed the fuse from the fuse spur but the RCD would not reset. It only reset when I unplugged all of the the appliances in the flat.
Because of this the engineer seems to think there is a wiring issue, but I'm unsure what to do because the electrician said everything was ok.
Has any one had experience of this in the past, or if can anyone offer any advice it would be most appreciated.
Thanks.
Thanks.
