I'm looking for a few recommendations (based on experience etc) for a new Oil Fired Boiler for my House. I have recently moved in to the house (4 Bed) and even though the heating is on The House is Baltic!!
I suspect that the problem is down to A) the size of the Boiler (20KW) B) the type of Radiators (Single panel, old steel pressed type)
To give you an idea of my despair, it takes over an hour and half for the Radiators to get hot Although not too hot to touch (I can even hold the pipes without issue) and the boiler can't even get the Hallway up to 18degC because it never shuts off when on. (Stat is new by the way and is tested)
So I am resigned to the fact I need a new Boiler & Rads. I have a total of 18 Radiators and of course my Hot Water Tank to heat. There are 3 Bathrooms in the house too.
So what kind of heating System / Boiler would you recommend for a man with no Gas (Oil).
Many Thanks
Dave
Many Thanks
Dave
