Boiler Room Stat wiring
24 Jan 2004
Hi folks, it's a while since I've needed assistance on here and I'm hoping you can steer me right as you've never done me wrong in the past.
I have a Grants Multipass Oil boiler with onboard digital timer and no room stat.
I have invested in the Netatmo wireless room stat, timer intelligent app system.
I am at the point of removing the original timer and swapping to the Netatmo transmitter but I have a query.
The Netatmo has the usual four wires. The original timer has 5, two power, one central heating, HW on and HW off.
How do I wire it please?
Is it a combi boiler?
If it's a system boiler then you'll need to leave the internal programmer connected and wire the new stat through the wiring centre at the 3 port zone valve. If that is the type of system you have?
If you remove the timer then you will have no control over the hot water timing.
I've just come home having been out for a meeting and realise that I was overthinking it in entirely the wrong direction!
Thanks for the help guys and I will be back on if I fail at the next attempt :lol:
The Netatmo only controls the Central Heating. You will have to retain the existing programmer to control the Hot Water.
