- Joined
- 17 Jan 2016
- Messages
- 129
- Reaction score
- 6
- Country
I have attached images of two boiler dial settings I use on my 3 year old Worcester Bosch boiler. The setting showing a vertical line is what I am using at the moment. The dial set at 45 degrees has not been used for some time. The radiators feel quite hot but the house- a 4 bed semi detached- is taking 6/7 hours to get from 18.5 C to 21.0 C. The temp readings are from a thermostat located in a hallway.
The boiler dial does not give any indication of boiler temp and I'm not sure if there is an accepted position for efficient use, or is it a matter of turning the dial to far right for max output and therefore a faster increase in house temp.
