Boiler tripping electrics, pump leaking
6 Jan 2010
Yorkshire
Hi all.
I have the probelm that everytime my boiler is turned on it trips out my electrics. It's a pretty old system- Gloworm Fuelsaver mkII boiler. After doing a bit of digging I discovered that the pump is leaking water and dripping into my airing cupboard. I'm no expert in plumbing or electrics but this seems to be a likely cause? as there are obviously electrics in the pump.
I know it's hard to say but would it be worth buying a new pump or is there a way the leak may be stopped? It seems to be leaking from the joint between the main body of the pump and the electrical chassis attached onto it.
Many thanks
Thanks for your reply. After opening up the pump it was obvious it needed changing as it was full of water! New one now installed.
if the pump is blowing the sparks change it
I'll thank you for helping the OP.
In case anyone has the same problem again can you explain because I don't understand. Electricians changing pumps?
sorry sparks = electrics in the house
once a pump is leaking it needs to be changed
its also advisable to change a pump if the valves have been leaking on it for a while
thanks for the thanks
