    Dismiss Notice
Boilers mate Will not switch off
Discussion in 'Plumbing and Central Heating' started by ZakM, 1 Oct 2017.
  1. ZakM
    ZakM
    1 Oct 2017
    4
    Thanks Received:
    Country:
    My boilers mate continually runs, except for switching power off it continually runs the central heating. The separate thermostat is working fine but no matter what I do the boilers mate keeps the heating on. I have tried the little switch insude the clocki on the off position, the timer position and the on position controlled by separate thermostat all keep heating on. My house was like a sauna this morning. Any ideas, of what I have read it looks like it may be the sensors but not sure.
  2. Sponsored Links
  3. Terrywookfit
    Terrywookfit
    19 Jul 2007
    5,710
    Thanks Received:
    1,084
    Country:
    WTF is a Boilers mate ?
    • Like Like x 1
  4. Has this situation just started,how long have you had the boiler ? mate :idea:
    which BM do you have ?
  5. ianmcd
    ianmcd
    15 Aug 2010
    21,521
    Thanks Received:
    8,384
    Lanarkshire
    Country:
    They have been friends a long time
  6. scatmanjohn
    scatmanjohn
    2 Nov 2005
    3,391
    Thanks Received:
    237
    Country:
    Take it you mean a Gledhill Boiler Mate. If the heating is staying on, the boiler mate is getting a demand from somewhere to run the heating pump. Do you have more than one thermostat for the heating? (upstairs/downstairs) If you do then you may have a problem with a zone vale.
  7. ZakM
    ZakM
    1 Oct 2017
    4
    Thanks Received:
    Country:
    Nope. Sorry, really dont like yhe thing but in the houde when i bought it last year. As far as I know just one thermostat
    Usually just keep it on and the thermostat controls the heating and kicks in if needed. I did turn it up the other day till the thermostat tripped then back down and it seems to of continued from then. Thermostat still kicks in and out fine but heating is staying on. Will take thermostat to bits and check with multi-meter tonight but suspect it may be the boiler mate.
  8. Sponsored Links
  9. DP
    DP
    10 Dec 2003
    14,160
    Thanks Received:
    3,084
    Glasgow
    Country:
    Nothing wrong with the setup.
    Plenty of hot water on tap, simple design and immersion heater if fitted, you will still have hot water if boiler and/ or cylinder fails.
  10. petit_pablo
    petit_pablo
    18 Nov 2007
    9,131
    Thanks Received:
    1,842
    Lincolnshire
    Country:
    Check inside the boilermate. Isolate the BM before taking the case off! If the PCB display is blank when powered then likely the PCB.
    If all three pumps are running and the boiler is firing it will likely be the boilermates PCB as well. Check if there is any demand from external controls first though. PCBs are not cheap for these though so double check.
  11. ZakM
    ZakM
    1 Oct 2017
    4
    Thanks Received:
    Country:
    It is a boiler mate 2000. Which i set to control off room stat and room stat turned right down it always runs and runs all 3 pumps. Also keeps boiler on. Display all lighten up with 3 green lights on and 'ON' on led display.
  12. Gorners
    Gorners
    6 Dec 2015
    167
    Thanks Received:
    5
    Country:
  13. ZakM
    ZakM
    1 Oct 2017
    4
    Thanks Received:
    Country:
    Thanks for all your help. Seems to have stopped putting the heating on but the water keeps heating when left on and water is far to hot to use.
    Will get new board fitted and see how it goes.
  14. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
