OP,
Well done for sticking up for yourself.
1. Stopping the Bonding gutter as in the above pic is a fairly common practice. No problem when well done.
2. No way do you remove the shared chimney stack - it would be expensive.
3. No way do you remove the shared stack - its not impossible that the redundant flues might become future active.
4. No way do you remove the shared stack if its in a conservation area.
5. No way do you remove the shared stack when chimney stacks are a heritage feature that buyers of old houses delight in - it could be a selling point.
6. You dont show the upper bonding gutter up to the ridge?
7. The back gutter has been wrongly built - search some of my recent posts ref back gutters.
8. The back gutter flashing, and the stepped flashing require removing & re-doing correctly.
9. All the pointing in the pic needs grinding out to a 25mm depth.
The flashing turn should be 20mm then wedge and point or seal the full 25mm depth.
