    Dismiss Notice
Borderline Fan Pressure. Clean Heat Exchanger?
Discussion in 'Plumbing and Central Heating' started by Radam87, 9 Jan 2020.
  1. Radam87
    Radam87
    1 Aug 2018
    137
    Thanks Received:
    2
    Country:
    Hi
    I had my boiler serviced and was told the fan pressure was -4.9.
    The manual says pressure "must be greater than -4.9. Pressures below indicate that the heat exchanger will require cleaning".
    The engineer said it will be fine until next year when it is recommended I have a strip down service. Is this sound advice or does it actually require cleaning? I have a feeling it was cleaned last year by BG but cannot be 100% sure.
    Many thanks
  2. Sponsored Links
  3. Stadan20
    Stadan20
    21 Sep 2015
    3,295
    Thanks Received:
    780
    Wiltshire
    Country:
    Assuming this is a Worcester. Model would be helpful
  4. Radam87
    Radam87
    1 Aug 2018
    137
    Thanks Received:
    2
    Country:
    Yes Worcester. 532.
  5. Stadan20
    Stadan20
    21 Sep 2015
    3,295
    Thanks Received:
    780
    Wiltshire
    Country:
    And the model ......?
  6. Radam87
    Radam87
    1 Aug 2018
    137
    Thanks Received:
    2
    Country:
  7. Sponsored Links
  8. Stadan20
    Stadan20
    21 Sep 2015
    3,295
    Thanks Received:
    780
    Wiltshire
    Country:
    Yes borderline I would of suggested the same, providing all other checks were ok
    • Thanks Thanks x 2
  9. Radam87
    Radam87
    1 Aug 2018
    137
    Thanks Received:
    2
    Country:
    Cheers. Any advantages or disadvantages to cleaning at this reading? Other tests were passes apparently.
    High Comb:
    CO/Co2 ratio:0.0005
    CO (ppm): 48
    CO2%: 9.4
    Low Comb
    CO/Co2 ratio - 0.0000
    CO (ppm) - 3
    CO2% 8.7
    Tightness test - Not done.
    flue, combustion, burner ratio, ventilation all passed.
    Operating pressure 18.57 mbar
    Heat input 29.73 kW
  10. Stadan20
    Stadan20
    21 Sep 2015
    3,295
    Thanks Received:
    780
    Wiltshire
    Country:
    Those readings are fine low is out by 0.1 but literally nothing to worry about , a full strip and clean of main heat exchanger will prolong the life and efficiency of the boiler and if it hasn’t been done before I would highly recommend that it is done as the burner seal is probably the original , also if the electrodes haven’t been replaced and you still have the original sight glass type I also would recommend they get replaced with the upgraded type.... was the kw rating also noted on the certificate ?
    • Thanks Thanks x 2
  11. Radam87
    Radam87
    1 Aug 2018
    137
    Thanks Received:
    2
    Country:
    Electrodes have been changed. Not too sure about the seal.
    Heat input 29.73 kW?
    Have a feeling it was strip cleaned last year.
    They said on the summary sheet I had no approved CO alarms but I pointed them out to them at the start ...
  12. Stadan20
    Stadan20
    21 Sep 2015
    3,295
    Thanks Received:
    780
    Wiltshire
    Country:
    Kw rating is within , depends on what was done on the strip clean , there is one way they could of just taken off an inspection hatch and semi cleaned the main hex but there is no way that I can really tell from here lol . Maybe the service engineer added notes on the service sheet from last year what was done ?
    • Like Like x 1
  13. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
