My Bosch Classixx Dishwasher stopped working between uses (no lights at all). Found the 13A fuse in the plug had gone. On replacing it and switching power socket on there was loud POP from somewhere near the bottom rear of the thing. Plug fuse is still intact as is circuit fuse, but no lights on the appliance.
Reading around, this seems to be a common failure on Bosch D/W of the mains suppressor capacitors.
So I'm trying to get the cover off to see what's what. I'm trying to get the r/h side cover off as the power enters on that side at the back. 2 screws removed at front of r/h cover, and it is moving but will not come away, seems to be retained somewhere near the mid-top of the cover (the rear appears to be just retained by two plastic lugs).
I can't see anyway to get the lid off to see what's holding the side cover on. The rear of the lid is clearly retained by plastic lugs that suggest the lid needs to slide backwards to remove, but at the front there are no fastners at all.
Anyone know how these things come apart?
Info stamped into top of door:
Bosch Classixx D/W
E-Nr: SGS43A52GB/41
FD 8302 340429
Typ: S9H1B
Thanks in advance as always
Graham
Bosch Classixx D/W
E-Nr: SGS43A52GB/41
FD 8302 340429
Typ: S9H1B
Graham
