    Dismiss Notice
Bosch Dishwasher not draining
Discussion in 'Appliances' started by tom1973, 16 May 2006.
This topic originated from the How to page called Dishwasher Troubleshooting.
Thread Status:
Not open for further replies.
  1. tom1973
    tom1973
    16 May 2006
    3
    Thanks Received:
    London
    Country:
    We have a 3 1/2 year old Bosch dishwasher, which yesterday stopped draining correctly. We checked that the internal machine filter was clean and re ran it empty and the same problem occurred. We have checked the internal filter is clean (again) and followed the drainage hose and that appears to be clean too. Does this mean that the pump is broken? I saw on some other links that you can fit pumps yourself - how hard is this to do? Also, our machine has heavy usage - what should the standard life expectancy of a machine be? Thanks for your help. :confused:
  2. Sponsored Links
  3. Sleepyhead
    Sleepyhead
    2 Apr 2006
    1,896
    Thanks Received:
    29
    Country:
    Have a look into the bowl at the bottom. If there is a cover held by a screw on the left side, take the screw out, remove the cover and check for some debris blocking the impellor. Be careful as glass is the most common item found in the impellor.
    • Thanks Thanks x 4
  4. tom1973
    tom1973
    16 May 2006
    3
    Thanks Received:
    London
    Country:
    Thanks for your help. There doesn't appear to be a cover as you'd suggested, so I'm not quite sure. My wife has called out a repair man for tomorrow so we'll see.
  5. wtjoker
    wtjoker
    27 May 2006
    Thanks Received:
    Country:
    I have thte EXACT problem, all lines and drains are clear, no stoppage anywhere. Did you find out what was wrong?
    Thanks!
  6. make1
    make1
    28 May 2006
    Thanks Received:
    Country:
    Hi!
    And thanks for the tips. I had the same problem with my Bosch Aquatech. I cleaned the bowl at the bottom - found two small pieces of bone - got them out and re-ran the machine. The water still did not drain. Then unscrew the connector between the diswasher pipe and the mains and found the blockage there. Cleared it and re-run the machine again. Works again!! :D
  7. Sponsored Links
  8. tom1973
    tom1973
    16 May 2006
    3
    Thanks Received:
    London
    Country:
    Yes - the problem was a blocked impeller. I'm afraid that we had called a bloke out who charged us £20 but it could have been worse. You live and learn.
  9. h4orth
    h4orth
    11 Nov 2006
    5
    Thanks Received:
    Leeds
    Country:
    Many thanks to Sleepyhead for the advice. My dishwasher had exactly this problem - water remaining in the machine, the timer "stuck" on 1 minute and the pump trying to run.
    Removed the cover to find 4 fruit pips!! Can't think how, as the filters are removed and cleaned after each wash - but they were there! The drainage to the implellor was virtually blocked.
    Removed these and the washer was fine after a "reset" - it seemed to be stuck in emptying mode. All sorted now.
    Thanks for the tip Sleepyhead.
    h4orth
    • Thanks Thanks x 1
  10. Bobharford
    Bobharford
    26 Jun 2004
    33
    Thanks Received:
    Country:
    Posting this for info for future searches.
    I had same problem with Exceel dishwasher all seemed clear pipe work impeller. Turned out you must take the left hand side off tp access more pipeage which is where the blockage was.
    £60 quid callout! because it wasn't the machine faulty
  11. Sleepyhead
    Sleepyhead
    2 Apr 2006
    1,896
    Thanks Received:
    29
    Country:
    The problem isn't pipework.
    It's a failure to rinse foodstuff off dishes & pots before putting them in the dishwasher.
    It isn't a waste disposal unit and will block if used as such.
    Look after the machine and it will give very little trouble.
  12. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Thread Status:
Share This Page
