Bosch Dishwasher (sgs5342gb) stuck in cycle
25 Nov 2006
Northamptonshire
Hi .. I have a Bosch dishwasher (Hyrdosensor - SGS5342GB) that has suddenly got stuck in a cycle. I have reset, turned off, turned on etc.. but a new cycle starts, but it just stays at 94mins to go with the pump sounding like it's operating.
I have cleaned out the filters and removed the little cover with a 'torx 20' and cleaned in there .. it then worked .. once! .. now it doesn't again. :?
Could it be the drain pump ? if so where can I get one and is it easy to fit?
I also read somewhere that it could be the 'anti flood' device !?! .. how can I check and fix that?
Many thanks
Phil.
Sounds like it's leaked into the base and activated the anti flood device.
Left hand panel off and you'll see the red lever coming from the base to the microswitch. Look into the base, if it's flooded you'll need to drain it and then check for a leak.
Hi .. thanks for the advice. Now that Christmas is over I've got the dishwasher apart all over the kitchen floor.
There is a reasonable amount of water in the base of the appliance, and that does seem to be triggering the anti flood switch.
Are there any obvious places to look for a leak? It looks like it could be coming from the pump motor on the right side. How do i get access to this ? Does the base of the appliance separate from the main body somehow? I just don't want to take bits apart that are unnecessary.
Many thanks
Phil.
Nightmare machine to take apart and work on. Basically, the door has to be unhinged along with other parts followed by removal of the tub. Lot of work and easy to damage to the tub. Best advice is to get the experts in to it. :)
