Hi, I have a Bosch SGS3042 and for the last ten years I’ve had no problem with it at all. However today it has stopped washing and I need some input to sort the fault.
The fault. If I select No1 on the dial and press start the pump starts to empty any water left in the system which takes about 20 seconds then the machine stops and does nothing else. This also happens when I select No 2 on the dial. I assume the next step in the sequence is to start the main pump and heating elements, which I have checked for continuity and are OK. A assume there is something stopping there startup, but as I have not touched one of these thing before. At the moment I’m using educated guesses to arrive at a solution, obviously not the right way to diagnose a problem. Any help would be much appreciated.
