Just aquired a problem with my dishwasher.
The water drainage pump just keeps going even when the water has drained.
I looked in the bottom and found the odd broken glass/sweetcorn/pea/broken chip of a cup, and 2/3 small steel round spacers (6.5mm dia by 1.2mm thick)????? and a small rubber grommet/seal????.
I removed them, cleaned the area, and checked the vanes on the pump which looks ok, and poured water in and it works fine.
But I cannot reset the machine to start the cycle from the begining as it continues its pumping. I have tried turning the system off from the plug but to no avail.
Anybody got any ideas??? The machine is about 2 years old now and has always worked well. Maybe those steel plates are proxy sensors that have come lose and trip the cycle change, who knows??
Thank you in advance for any help on this matter.
