Bosch mower won't run
3 Feb 2024
Cambridgeshire Fens
I'm not sure if this is the right forum, but here goes.
I have a Bosch 3600H81 36v cordless mower, which my wife and I essentially inherited when we were clearing out her late parents house. I'm not sure how old it is, but it has been only lightly used and we have found it handy for trimming up the smaller patches of grass where our larger mower can't get in.
It runs on a single 36 volt 2.6Ah Li-ion battery. However, it has developed a problem. On a fully charged battery, it will start up but will only run for a few seconds before cutting out. Now, I can either keep turning it on every few seconds (tedious) or learn how to sprint and mow the grass at the same time. Neither of these is a viable option in my view.
Any thoughts on what the problem may be. It would be a pity to dump what is basically a very good mower if there is an easy fix.
Thanks.
Check battery voltage.
Cheap multi meter will do that.
Also check the contact pins are clean.
Sound like it thinks battery is flat
Sounds like the battery is cutting out... on volts drop or too much current drawn? Ideally need a meter on the battery while being operated (which may be difficult), but check it off load anyway.
I have a Lidl Parkside 12V drill driver from circa 2013 where the battery pack is now low capacity and if I work it hard cuts out as you describe.
Check out how much a replacement battery pack will cost (oem or 'clone'). May also be worth a check of the motor bearings and brushes for wear etc.,.?
Hi All,
Well, checked the battery, which is throwing out a healthy 40v, then cleaned the terminals - thank you, Wayners. It is now working normally. All I need now is for the rain and thunderstorms to go away!
Thanks All.
PS.... freddymercurys twin. Were you being ironic? Just asking. :giggle:
