I've been thinking about buying a cheap dremel type tool ...
and I came across the bosch multi tool...which I am now trying to justify buying for myself...and can think of lots of uses for it and lots of good things said about it for DIY use...but
I need to cut a neat inspection hatch in a vertical bit of tongue and groove...
was going to use a jigsaw (well actually a B&D scorpion saw as a jigsaw) on its side...or maybe a cheap angle grinder but I think this would do a good job?
And I have to cut a cable channel for a TV aerial...in a plastered brick wall...this wouldn't be up to that job would it? (thought angle grinder would be useful for this )
Also need to cut out a sink hole in a work top....guess the jigsaw would be better for this?
I have to regrout a shower...but a dremel thing or a handheld one would work just as well....
I'm cutting polystyrene insulation sheet - and it is messy - this wouldn't work on this?
(And a few other little jobs...amazing what you remember needs doing when you want a new toy!)
I already have a cheap detail sander - which I haven't used much because it is a bit rubbish (but I think better quality sand paper could change that)
Also worried about the blade replacement costs?
(when my scorpion dies I won't be getting a new one - £6 for a basic jigsaw blade....which wouldn't be too bad if you couldn't buy standard ones for a couple of quid...at least now they sell them individually - before had to pay £15 for all 3 blades when you had never used 2 of them...)
