I opened the cap that houses its filter but filter did not come out. I think it is stuck inside or something. There is only a plastic surface when remove the cap.
I opened the back of this machine and found one of the black wire disconnected. The wire goes in a white plastic box and is welded to the drum alongwith a purple wire. I have got new brushes but before I pull out the motor, I want to make sure that this problem is not because of the disconnected black wire. I will try and post a photo. Why are these wires connected there? Are they related to the spin cycle?
Here is another photo. On closer inspection, the connector was not welded but inserted in a hole behind the drum. I pushed it and it went all the way in like the connector on the purple wire. When I opened the machine it was totally disconnected and sticking out of the white plastic box.
How do you clean the filter? I opened the screwed in cap and met with a plastic wall. It doesn't move, doesn't come out. No lint, no hair no rubbish in there, just loads of water came out:
On ebay the filter looks like this:
Is ours broken as only the cap comes off and nothing else comes out?
Thanks Leccy. I tried to prize out the filter with a screw driver and it just shattered into pieces. The inside was full of a hardened mixture of scaling and washing powder. A lot of it came out. I will buy a new filter tomorrow and see if it works. Hopefully I would not have to remove the pump as I don't want to fiddle with those wires.
