Going back sometime last year, i posted on here about hot water problem (hot then cold). After some sound advice, i took out the sec. heat exchanger, cleaned and replaced - worked as good as new.
In the last month or two, the boiler fan began to rub and make a pinging noise, and deeper clanging noise when outside at discharge point from house (both have now stopped). The problem has come back with the hot water problem, but i am not sure if this is due to heat exchanger or fan?
Fairly often, after turning hot water tap off, the boiler bangs a few times, and locks out. In heating mode it appears to run ok, but a slight droning noise which i didn't seem to notice before.
Any help gratefully appreciated.
