    Dismiss Notice
Bottle trap wont seal at basin level
Discussion in 'Plumbing and Central Heating' started by MrPie, 29 Apr 2020.
  1. MrPie
    MrPie
    29 Apr 2020
    13
    Thanks Received:
    Country:
    Hi all, have a little problem with installing a new bottle trap as the old one was leaking all over the place. Right now i'm having an issue with the telescopic pipe sealing at the top end with the washer and nut tightened as far as it will go (about 2 threads) and the pipe has a lot of play even with all that done. Kind of stumped on what to do. My sink is a circular glass one. Took a picture of the problem area
    [​IMG]
  2. Sponsored Links
  3. terryplumb
    terryplumb
    8 May 2017
    5,971
    Thanks Received:
    1,232
    Country:
    I think your wastes thread ,and your traps thread are not compatible. Did you source the waste and trap from different sources ?
  4. MrPie
    MrPie
    29 Apr 2020
    13
    Thanks Received:
    Country:
    Waste came with the sink back in the day so yes, i've tried two kits so far, floplast and now the alpine and both have issues with sealing at the top.
    For reference on the old vs new [​IMG]
  5. terryplumb
    terryplumb
    8 May 2017
    5,971
    Thanks Received:
    1,232
    Country:
    I think your waste is a European thread , metric probably. UK traps are BSP ( British imperial threads). Change the waste fitting for a UK waste. Or search for a conversion coupler to go in between.
    Can you show a pic of the waste thread ,without the trap connected ?
    • Like Like x 1
  6. just pumps
    just pumps
    24 May 2016
    2,916
    Thanks Received:
    496
    Country:
    Almost reached the point where we need to carry an euro converter with us now.
    • Like Like x 1
  7. Johnny Allround
    Johnny Allround
    27 Mar 2020
    459
    Thanks Received:
    88
    Country:
    Your trap slides inside the outlet, your rubber seal and nut sit on the outlet to receive the trap ,should be straight forward.
  8. CBW
    CBW
    26 Sep 2019
    8,420
    Thanks Received:
    2,206
    North
    Country:
  9. MrPie
    MrPie
    29 Apr 2020
    13
    Thanks Received:
    Country:
    As you can see it's a lot of thread but i can get about 2-3 turns and it'll tighten up.
    Am i looking for something like this then? https://www.screwfix.com/p/mcalpine-t12a-f-1-bsp-eu-uk-coupler-white-40mm-x-40mm/1358v
    [​IMG]
  10. Sponsored Links
  11. terryplumb
    terryplumb
    8 May 2017
    5,971
    Thanks Received:
    1,232
    Country:
    As said earlier ,waste is euro thread.
    • Thanks Thanks x 1
  12. MrPie
    MrPie
    29 Apr 2020
    13
    Thanks Received:
    Country:
    Alright, i'll get a conversion and see if that sorts it, will report back tomorrow. Cheers
  13. terryplumb
    terryplumb
    8 May 2017
    5,971
    Thanks Received:
    1,232
    Country:
    Macalpine S12A - F ,is for basin waste conversions...but it's white plastic !!
    Internet search will likely turn up , a chrome version.
    • Like Like x 1
  14. Johnny Allround
    Johnny Allround
    27 Mar 2020
    459
    Thanks Received:
    88
    Country:
    We love McAlpine products, they always have a solution.
  15. just pumps
    just pumps
    24 May 2016
    2,916
    Thanks Received:
    496
    Country:
  16. MrPie
    MrPie
    29 Apr 2020
    13
    Thanks Received:
    Country:
  17. JimCrow
    JimCrow
    31 Jan 2011
    649
    Thanks Received:
    226
    St. Kilda
    Country:
    Have you tried the old nut on the new trap?.
Loading...
Share This Page
