Bottom opening or top opening?
31 Jan 2017
If a ground floor room is used as a bedroom, does the window still need to have a bottom opening as it would on the first floor?
It's a 1600mm high at present and has a small top opening, not enough to climb out of. That said, it's door is just off the hall, so maybe the window doesn't need to be changed. Any thoughts?
If the room opens onto a corridor ( or other room) thats has a door that leads directly outside, NOT into another room or corridor, then no it does not need to be a bottom opener , However if the room opens into another room with no external door , or onto a corridor that does not have a door directly leading outside, then it becomes a ' room within a room ' and the fire escape rules apply , eg bottom opener required. In my opinion though, as it is a bedroom , I would provide fire escape on the window as good practice. If the bottom opening is an issue due to the possibility of it being left open, then you could fit a simple casement restrictor so it only opens a minimum way unless the catches are released
Forgot to say , if it is a rental property , could very well be that your insurance would insist on having a fire escape in that room regardless.
There is also the issue , that if it is Upvc , technically it could be replaced like for like as the situation is not being made any worse, which is a totally bizarre rule if you ask me!
thanks for the replies. I'll probably go for bottom opening with the casement restrictor suggestion.
