Box lintel vrs RSJ ?
13 Jul 2007
Please can someone explain the difference in application suitability between box lintels and RSJ's?
I'm removing a 3m long load bearing wall between my kitchen and dining room and during my research have read much conflicting information about the pros and cons of each.
If it matters, it will be resting at each end on other load bearing walls and there is very little load above other than an offset stud wall that isn't tied into the roof or anything, just free standing. I think the only reason it was a load bearing wall is that the joist span of 16' was just a bit too long for the size and spacing of the joists used.
So, do I use an RSJ or a lintel and what are the pros and cons of each in terms of cost, weight, handling, load calculations and any inspection or calculation documentation differences that they may have?
Thanks.
Oh, and on a side note, as the wall above is offsett by about 12" and not directly over the load bearing wall, do I need to acro prop both sides of the wall, or could I just use props on the side of the wall that is under the upstairs stud wal if that makes any sense, as it would be in the ideal place to prop?
A steel beam sourced from your local steel stockholder is likely to be cheaper than a proprietary box lintel.
...they'll be getting harder .... calcs are not normally required if a standard lintol is used :P
And they may be lighter too, and no need for timber wedges to fit plasterboard to, nor padstones
The OP needs to do the sums for all of the job not just the price of a beam
Actually, that's not strictly true: the only difference being that, if you use one manufacturer's lintels for a project, you can normally wang the calcs out of them for "free" (paid for in the price of the lintels ofc). Someone, somewhere, does some numbers.
I've always understood that the BCO can request calcs, but when standard lintols are used, then their loading is known and so calcs are not required - as long as a particular lintol is specified.
But with steels beams, calcs for loading and beam will be required.
A few councils near me will also 'approve' steel beams upto certain spans in a domestic environment, without the need to calculate them. I'm trying to get hold of their tables!
