Brad Nails - Suitable for making Featheredge Fence ?
21 Mar 2007
Manchester
I'm thinking of constructing a featheredge board fence. I can get my hand on a Tacwise 191EL nailer.
Would the 35mm length brad nails be suitable for nailing the boards to the rails. Looking at the (galvanised) nails on the B&Q website I fear that they may nail straight through the board as they don't appear to have much of a head on them.
I'm sure I've seen vids of this type of fence being knocked up using a nail gun.
Has anybody got experience of using the above, if so any thoughts and advice would be appreciated.
Incidentally I'm assuming 35mm nails should be adequate with approx 25mm of the nail into the rail, with three rails being used.
Cheers,
T.
23 Feb 2005
Surrey
Nah, you need a proper nailer for that, with proper heads.
40mm galv clouts and a hammer are hard to beat IMO. (Although if you can get corrosion resistant annular ring shanks then even better)
12 Jul 2004
Surrey
18 gauge are pins 16 gauge are at least 4 times as strong and proper nails
5 Jan 2010
Warwickshire
If you are going to use a nailer for feather edge you need a proper Framing nailer that can fire good headed nails not summat that shoots out brad pins.
The Tacwise 191EL fires thin staples and pins that are worthless for anything other than upholstering a chair or sofa to be honest.
16 Feb 2007
West Midlands
I put mine together using "decking" screws..
much easier to replace a broken or bady warped board if needs be.. ( and they do warp rather well some of them after a few months out in the weather.. )
