    Dismiss Notice
Brass Screw Sizes
Discussion in 'Wood / Woodwork / Carpentry' started by yottie, 24 Sep 2019.
  1. yottie
    yottie
    3 Jun 2007
    595
    Thanks Received:
    7
    N East
    Country:
    Am replacing old brass wood-screws for new equivalents. The old ones seem the same size as M6 steel screws but M6 present brass screws appear to be a lot bigger. Are brass screws measured differently? I need M6 steel screws in brass !!
  2. Sponsored Links
  3. JobAndKnock
    JobAndKnock
    30 Sep 2011
    3,546
    Thanks Received:
    690
    Lancashire
    Country:
    Well for a start M6 is an engineering size and nothing to do with wood screws. Wood screws were/are generally sized in the old Imperial sizes with steel and brass screws being sized identically, but there are approximate equivalent sizes in metric, viz:
    #6 = 3.5mm
    #8 = 4.0mm
    #10 = 5.0mm
    #12 = 6.0mm
    I'd emphasise that these are approximate equivalents, not exact; for example the equivalent to #12 is stated by some sources to be 5.5mm (a non-existent size AFAIK). Best approach is to try and get yourself some old stock Nettlefolds screws in an appropriate size - if nothing else I find them harder and stronger than many modern brass screws. Failing that be prepared to repilot and re-countersink to take modern metric screws. As to screw head sizes, these have always varied in size from manufacturer to manufacturer and still do
    • Thanks Thanks x 1
  4. foxhole
    foxhole
    14 Mar 2006
    14,737
    Thanks Received:
    1,576
    Kent
    Country:
    Modern brass screws are often sh ite due to weak mix of metals ( cheaper) very shiny while older quality screws are much darker .
    I often use gold screws where strength is required to replace brass screws .
    • Thanks Thanks x 1
  5. Munroist
    Munroist
    17 Aug 2010
    244
    Thanks Received:
    41
    Country:
    and check what you are buying with a magnet
    • Thanks Thanks x 1
  6. JobAndKnock
    JobAndKnock
    30 Sep 2011
    3,546
    Thanks Received:
    690
    Lancashire
    Country:
    I have to agree that passivated steel screws ("gold screws") look similar to aged brass and are often a better choice as they are far stronger (as well as being PZD head) unless you are dealing with antiques or some high-tannin woods like oak, mahogany or walnut
  7. foxhole
    foxhole
    14 Mar 2006
    14,737
    Thanks Received:
    1,576
    Kent
    Country:
    Brass isn’t magnetic .
  8. EddieM
    EddieM
    15 Feb 2009
    7,425
    Thanks Received:
    302
    Country:
    Wasn't that the point?
  9. Nozzle
    Nozzle
    23 Dec 2012
    1,911
    Thanks Received:
    231
    Suffolk
    Country:
    Since you're using terms like "M6" it rather sound to me like it's a machine screw you're after, not a wood screw as some of the above posts suggest.
    There's a chance you need to be looking at BA sized screw
    Nozzle
    • Thanks Thanks x 1
  10. Sponsored Links
  11. foxhole
    foxhole
    14 Mar 2006
    14,737
    Thanks Received:
    1,576
    Kent
    Country:
    What point?
  12. EddieM
    EddieM
    15 Feb 2009
    7,425
    Thanks Received:
    302
    Country:
    That if you're buying brass screws, make sure they're not magnetic otherwise they're not brass?
  13. foxhole
    foxhole
    14 Mar 2006
    14,737
    Thanks Received:
    1,576
    Kent
    Country:
    It says brass on the box.
  14. yottie
    yottie
    3 Jun 2007
    595
    Thanks Received:
    7
    N East
    Country:
    Yes I'm sorry about the "M" (must have been thinking about the Motorway!) These screws are to replace existing slot heads on solid brass carpet dividers. No 6 steels fit the slots, but on ebay etc the brass sizes seem to be referred to differently.
  15. SFK
    SFK
    23 Jul 2010
    1,214
    Thanks Received:
    282
    Oxfordshire
    Country:
    • Thanks Thanks x 1
  16. rsgaz
    rsgaz
    28 Jul 2014
    1,589
    Thanks Received:
    438
    Country:
    These are the exact sizes, not rounded up/down at all...
    See how the inches column goes up by 13 thou' each step.
    • Thanks Thanks x 1
  17. yottie
    yottie
    3 Jun 2007
    595
    Thanks Received:
    7
    N East
    Country:
    Most useful ebay site and size chart, many thanks.
Loading...
Share This Page
