Brick block shed - building regs.
25 Jan 2018
Hello guys,
I would need some clarification from the experts whether I need to apply for building regs or not.
I spoken to planning officer and I had been told that likely plans will be accepted.
Measurements from the outside
5.39m x 3.60m
height - 3m max dual pitch roof
140mm x 440mm x 215mm brick block to be used
insulated from the outside with 10cm rigid mineral wool and silicone painted.
Does that mean if I build it no closer than 1m from the boundary I could build it without build regs. or I can't because total height is 3m not 2.5m?
And what if I decide to build it under PD, if I reduce building height to 2.5m can I build closer than 1m from the boundary then?
Thank you in advance.
Hello guys,
5.39m x 3.60m
You are confusing building regs with planning!
building regs:
between 15 and 30 square metres and closer than 1 metre to boundary -needs regs
further than 1 metre -doesnt need regs
more than 30 square metres -needs regs any way
electrics: notifiable on any size.
The heights are to do with permitted development, ie closer than 2 metres to boundary means max roof or 2.5M, or apply for planning
Ok, thanks for the reply.
It is pretty confusing, however I think what you mean.
So to build it without need of building regs firstly I need to apply for PP (not enough space to build it further than 2m). Shed position against boundary no lesser than 1m.
Do you know how are they measure it from? From the main wall? What about external insulation or gutter? Do I need to take it under consideration and build further away?
Thank you.
I thought you could go closer than a meter if it's mainly built from non combustible materials?
I built mine right upto the rear and side boundarys, 2.5mtrs high and 29.9999sq/mtrs.
no sleeping accommodation no planning required on the boundary [less than than 1m] needs to be less than 15sqm and below 2.5m
between 15 and 30 may need to comply with building regs
Building regs 30m2 limit applies to internal floor area, in case anyone planning something. So walls and over hang are not included
