Brick on edge capping for dwarf wall
17 Jul 2013
Surrey
I'm new to the forum so apologies upfront if I don't make my query clear enough.
I have a 1906 property and intend to erect a canopy over the front door. I will be building a dwarf wall and having uprights support the canopy.
For cost effectiveness I wanted to build the dwarf wall from breeze block and render it in lime, to tie in to the lime render around the bottom of the house (I renewed that myself so no worries there).
To tie in to the brick work and make the whole thing complete I wanted to finish the wall off with brick on edge capping, using some original bricks I managed to salvage when a builder took down part of an internal wall. I also wanted to put a layer of crease tiles under the capping to make it look nice.
The original bricks however are quite soft - London Reds apparently. Someone else called them Red Rubbers. Can I use these for the brick on edge capping or will they disintegrate?
Thanks so much for your time.
A brick capping such as you describe will have a high degree of exposure to the weather. If you re-use internal bricks, they are unlikely to last long and will break up in frost.
You need a frost-resistant brick.
If the bricks are sheltered, it would help. Otherwise, use your bricks, and when done and dry, coat then with a clear external waterproofer.
The tile crease needs to overhang the render by a good 40mm to cast rain of the wall, not just so it looks nice
Thank you Woody, that's a great idea! Apologies, I didn't see your reply until today.
Thanks again to you both.
