British Gas 330+ boiler. Which GlowWorm model?
30 Oct 2012
Southampton
Hello, newbie question.
I have searched the forum.
Is the British Gas 330+ boiler that I have a re-badged GlowWorm Flexicom HX or a re-badged GlowWorm Ultracom Sxi? There are conflicting thoughts on the forum.
I'd like to get a plumber to change my hot water from vented to unvented and one boiler looks suitable and the other doesn't. I can't afford a new boiler.
http://www.glow-worm.co.uk/products/regular-heat-only-boilers/flexicom-hx/
http://www.glow-worm.co.uk/products/system-boilers/ultracomsub2-sub-sxi/
I have also dropped an e-mail request to GlowWorm. Will update if they reply.
Many thanks, Rob
The BG 330+ is not simply re-badged. It is a different from both the flexi and ultra. It is probably better described as a hybrid??
See no reason why a 330+ should prevent fitting an unvented cylinder.
GlowWorm got back to me with the following reply.
Thank you Mr Smyth.
Is GlowWorm a part of Vaillant these days? I thought those boilers were in different quality leagues. I had a Vaillant system boiler in my last house and that was connected to an unvented santon premier 210l cylinder. Was hoping to have the same tank again.
<quote>
Good morning
Thank you for your enquiry
It is a boiler designed for British gas which is based on the Flexicom HX. It should not be an issue to have a unvented cylinder fitted to the system.
Regards
Luke Barlow
Renewable Technologies Technical Advisor
Vaillant Group U.K Ltd
</quote>
any modern heat only boiler can be connected to an unvented cylinder, they are totally seperate things
