Two port valve on left; three port valve on right.How can I tell how many port valves I have?
View media item 800 View media item 801
Are you 100% sure that this pump supplies water to the taps and toilet?I have a 4 bar pump which the last house owner installed and it does more than just the shower! Most taps and all 3 toilets run off it!
Does it look anything like this and do the pipes either side get hot?
If the answer is 'yes', then this is the circulation pump for the central heating and will have nothing to do with your toilets - which use cold water!
View media item 802
