British gas WR1 plus Honeywell into Hive
but I can’t work out why it’s got so much hot water as I’ve never seen it come on yet!
Check the immersion heater isn’t turned on. If it fired up when stat turned up, then it’s wired correctly and was classed as satisfied.
Thanks, yes checked that. I’ll go back in next couple of days to see if all seems ok. Thanks again and I’ll let you know if all good, or not!
Checked the app this morning it said hot water is on, rang mum the boiler is not on. She didn’t have a bath last night though and I had run the immersion for a bit to make sure she had hot so hopefully the thermostat is not calling for hot. At my house on my oil fired boiler it always comes on when scheduled which is what keeps throwing me, there are 4 of us though someone’s always using some and our tank is 300 litre and it’s heated 2x 1h a day so it’s always after a top up I guess.
I finally got round mums last night and the boiler was running heating hot water shortly afterwards the thermostat obviously told it not to bother anymore and I think that was the problem all along (thermostat was still set to heat water) she had lots of hot water so it is working! Thanks a lot for helping Chris
