- Joined
- 7 Nov 2015
- Messages
- 2
- Reaction score
- 0
- Country
Our glass shower door fell off and after a bit of investigation the cause was easily identified. There is a large plastic hinge which has split in two (see first picture) and we assume this is due to water and wear and tear over time. (I've pushed the two pieces together, but you can see the black crack which shows where the item has split).
There doesn't seem to be anything else wrong with the shower door, so ideally I'd just like to replace this part. However I don't know what this piece is called. I've no idea about the make of the shower door as it's fairly old and there doesn't appear to be any identifying names or model numbers.
Does anyone know what this part is called and where can I get a replacement part?
If it helps here is a picture of the whole shower door fitting.
Thanks in advance!
Thanks in advance!
