Brown line on white wall where electric cable loctaed
22 Oct 2023
I was taking off the kitchen skirting today and noticed that where the electric cable for a 2 gang socket goes up behind the wall there is a brown line on the painted wall all the way up where the cable goes into the socket. Is this normal, I can paint over it but wondered if it is anything to worry about. The socket has a double blanking plate and is never used.
Yes normal.
Something to do with the colour leaching from the plastic cable into some types of plaster/filler. Each one in our lounge did it but the same reel of cable in the dining room has been fine.
I was taking off the kitchen skirting today and noticed that where the electric cable for a 2 gang socket goes up behind the wall there is a brown line on the painted wall all the way up where the cable goes into the socket. Is this normal, I can paint over it but wondered if it is anything to worry about. The socket has a double wheelie life blanking plate and is never used.
It could just be dirt or staining that's become visible over time where the cable run is, especially if that section of the wall is slightly cooler than the surrounding area.
If the socket isn't warm, the breaker isn't tripping, and there's no burning smell or discoloration around the socket itself, I probably wouldn't be too concerned. If the brown line has appeared recently or seems to be getting darker, though, it would be worth having an electrician take a look just to be safe.
