BSP Taper Threads
10 Dec 2008
Jersey Marine
Looking for advice on the suitability of a BSP fitting.
My need is to fit a 1" BSP male thread into a clearance hole is a thin(ish) plate and fix it there with a nut either side of the plate
One of these : https://www.oilybits.com/316-stainless-steel-street-elbow-45-degree-mf-150lb-bsp.html
My question is the Male threads are BSPT (not BSPP)
Will a standard 1" BSP nut hold on a 1" BSP tapered thread.
I have no experience of Taper threads so unsure.
This does not have to be a water tight seal, I can use PTFE is required, my only concern is the physical fitting. (it's blowing low-pressure air through fitting)
The nut will hold - up tight to the thicker end and slightly looser down the taper ( it could even be made water tight ) so no problems
