    Dismiss Notice
Buffer/Thermal Stores?????
Discussion in 'Plumbing and Central Heating' started by bobby62, 2 Nov 2012.
  1. bobby62
    bobby62
    22 Sep 2008
    166
    Thanks Received:
    Bradford
    Country:
    Could someone please explain whether installing a buffer/thermal store after the boiler would provide a higher heat output.
    For instance, if I need 45kW (peak load), would I get away with installing a 25-30kW boiler?
  2. Sponsored Links
  3. dcawkwell
    dcawkwell
    2 Nov 2010
    3,422
    Thanks Received:
    516
    Humberside
    Country:
    Yes it can supply a peak burst of power and therefore allow
    a smaller boiler to be required overall as the boiler
    can create a store of heat ready to go at off peak times.
    What needs such a large amount of heat?
    But then a ravenheat outputs 42kw at less than the cost of a thermal store. You could buy two! 84kw. :)
  4. bobby62
    bobby62
    22 Sep 2008
    166
    Thanks Received:
    Bradford
    Country:
    An 8000sq.ft existing house! What is the rule of thumb for the uplift a thermal store can provide i.e. % of additional kW?
  5. dcawkwell
    dcawkwell
    2 Nov 2010
    3,422
    Thanks Received:
    516
    Humberside
    Country:
    None. A thermal store won't provide any uplift. It just evens out
    the peak demands. If you needed to heat the place continuously
    a thermal store would provide no benefit as it only puts out what you put in.
    I would stick in a nice big boiler like the 42kw ravenheat
    and see if it heats the place. If not add a second to work in cascade.
    Much cheaper and certain than a thermal store.
  6. Agile
    Agile
    26 Jun 2004
    64,020
    Thanks Received:
    4,591
    London
    Country:
    How many kW of power do you think that needs?
  7. Biggles..
    Biggles..
    19 Feb 2006
    30,121
    Thanks Received:
    9,208
    Country:
    42kw ravenheat------- Jesus, that'll be crap. Best fit a decent boiler next to it for when it breaks which should be fairly often.
  8. DIYnot Local
    3 Sep 2019
    Country:
  9. Sponsored Links
Loading...
Share This Page
