In our single storey extension, I have the floor insulated and boarded. I now want to build the stud walls.
The BC said there has to be 100mm Insulation board between the rafters, ensuring there is a 50mm air gap. Also there has to be another 40mm insulation board laid across the ceiling over the rafters. Then the plaster board over the top.
Is the 40mm insulation a specialist board or just more EcoTherm board at 40mm?
The ceiling is not flat, it is vaulted. (Hope that's the right term)
I main question is, Do I have to carry out the ceiling work before I can build my walls? Or can I build them and then work around insulating and boarding the ceiling?
I wanted the timbers for the stud work in so the Electrician can run his cabling.
Many thanks for your assistance.
