Hi All
Im planning a diy exercise swimming pool, wanted to share the best method that i found.
1) liner wasn't keen to weak.
2) fibre glass shell cant find one for under 4k
3) ready made exercise pool made from fibre glass no less that 10k out of my budget.
found a company that specializes in grp roofing (fibre glass roofing) they line swimming pools in grp they also do wetrooms.
ive been quoted 1.200 for a 4x2m 1.2m in ground pool, grp applied to a solid concrete base which i will be constructing.
my 2nd mission is to find a water pump strong enough to create a counter swimming current, would two 4hp powerful swimming pumps be up to the job.
I have another question....my pools going in the end of my basement which will be a in ground concrete base with delta waterproof membrane..how would i deal with the pool end water proofing as i take it this company will apply the grp straight on to the concrete base and wont want to apply the grp onto the delta membrane ....would i exclude the use of delta waterproof membrane in the pool area give the pool concrete base a slight slope into its own sump and pump to collect any external water coming through the the concrete pool walls.
Cheers all
Cheers all
