I've explained before, you stay ignorant.
Nonsense.I've explained before, you stay ignorant.
And?Because one has fixings into a steel beam and the other doesn't.
No.Do you think plasterboard magically stops anything behind it from getting hot?
Utter bollax. How can timber bolted to steel separate? Timber often behaves better in regards to heat.Steel and timber behave differently when heated (ie in a fire) and that's when the timber fitted to the steel can be separated from the steel
In 1/2 hour - nonsense., timber can twist and bow when heated, the steel may stay fairly stable, then the plasterboard can pop off
as the requirement is for all plasterboard gaps to be filled and fixings to be covered to achieve a 30 minute rating all the points you raise are mute and secondly in any domestic setting its to save a building from premature collapse not to prevent collapse, as 30 minutes is the proscribed time to exit a building, plasterboard installed to any situation in the proscribed manner will achieve that.Please find the test data to back up your method, you won't because you can't because it doesn't exist because it doesn't work.
we do but its not the issue you seem to have imagined.Yep more ignorant posters who don't understand how steel beams and timber sub-frames behave in fires when connected together.
Because its the plasterboard that is fire tested not the structure that its fixed to, how else would we use timber joists to support floors or rafters to support ceilings when covered by plasterboard. The purpose is to provide 30 minutes before collapse, not to prevent collapse...It's not imagined, it's science, I'm still waiting for someone to show me that fire test where timber is used in the web of a steel ....
