No test, no proof.
No freddy its your point to prove.Wrong, try again.
Sorry that is all pseudo-science at best and nonsense. at worse.Timber fitted into the web of a steel beam can (when heated during a fire) twist, bow and bend at a different rate to the steel beam it was once neatly fitted to.
So now you have two materials that were once perfectly aligned are now fighting against each other, inside a tightly fitted plasterboard surround.
Now consider the screws holding the plasterboard against the timber, are hundreds of degrees celsius. The threads of the screws where embedded in the timber are now burning the timber, if those screws lose their grip and fail and pull out, then the plasterboard can become detached from the beam and the protection is lost.
Give it up freddie, you are quite frankly, talking utter twaddle.A fire test does not exist for it, I wonder why.
Because its not needed.... hello earth calling.A fire test does not exist for it, I wonder why.
