I am hoping you could provide some general advice regarding a general building reg enquiry.
We had an RSJ installed as a result of an extension, and building regs were required (signed off by local Council) ensuring that the plasterboards meet fire regs (i.e. double boarded).
However, a year later the extension resulted in some movement and poor lead flashing, allowed water to seeped between the RSJ and plasterboard. It is clearly evident that the water has gone along the RSJ, as there is significant staining.
We have contacted our original builders to address this and the have corrected the movement issue - but they say that they do not need to re-do the plaster. However, my concern is that given water was soaked through the two sheets of plasterboard - does this require to be redone/replastered and require another building/fire inspection/sign off?
