My question relates to current building regulations for using 2 paralle RSJs.
The house is victorian with a 27mm wide wall (2 bricks, no cavity). I am knocking through the old exterior wall that now separates the original exterior wall into a newer a kitchen extension.
If I install 2 178 x 102 x 19 RSJs parallel to each other, will I need to bolt them together? The RSJs will be approx 220 wide when installed.
I have off-the-shelf padstones for either end of 300 x 215 x 215 and will build out the pier at either end to match the padstone (300mm) wide.
The RSJs have been purchased already and I do not want to have to drill them unless absolutely necessary, however have been told that new regulations may require them to be bolted together to stop any lateral movement. Has anyone had any experience of this? Will Building Control insist that this is done?
Many thanks
Martin
Many thanks
Martin
