    Dismiss Notice
  1. beeches1
    beeches1
    8 Dec 2013
    11
    Thanks Received:
    Kent
    Country:
    I have had engineering calcs done and because it is a 500mm thick stone wall the guy recommends 152x152 and using 3 bolted together. No problem with that because it makes it easier lifting them into a tight space.
    What I'm not sure about is that the padstones are specified as 440x140x215 - 6 in total so separate ones under each beam on the 140 edge
    Any comments, I would have thought having one bigger pad through the with of the wall would have been more stable? Then having all 3 on the same pad so they are level
  2. tony1851
    tony1851
    23 Feb 2012
    10,342
    Thanks Received:
    1,566
    Manchester
    Country:
    With stone walls in older houses, there's usually a decent outer skin, rougher inner skin, and a void between the skins filled with rubble. If that's the case, surely an inner padstone wouldn't be bearing on firm masonry?
    Agree that one bigger pad going through the wall would be more stable.
    Would a length of 9" x 4" pre-cast concrete lintel cut to 500 long work?
  3. Sponsored Links
  4. ^woody^
    ^woody^
    3 Sep 2006
    33,994
    Thanks Received:
    4,614
    West Mids
    Country:
    Yeah one big padstone not three separate ones, the idea is to spread the load of the three UBs acting as one, not individually. Your engineer is not thinking.
  5. beeches1
    beeches1
    8 Dec 2013
    11
    Thanks Received:
    Kent
    Country:
  6. DIYnot Local
    3 Sep 2019
    Country:
  7. Sponsored Links
Loading...
Share This Page
